The rods will work, but it will be heavier... As far as strength goes, it will be stronger, but not in a useful way... the plane is light enough that the extra strength is not a benifit, just heavier.
You can always install them temp. with packing tape to get the final weight... if it is unacceptable, then remove and purchase the tubes.
Good luck.....
Levi Jordan
www.3DFoamy.com
