RE: robart struts
Not sure exactly how you were planning to run the screw through the strut, since the gear wire goes down the middle and you can't possibly drill through it...
The first problem that comes to mind is clearance in the retract frame. Screwheads or nuts on the outside of the Robart strut will hit the retract itself.
