RE: Final CAP-X Manual with pics & CG/Setup info AVAILABLE NOW!!!
Well it flys---I will give more details tommorow evening
I am going to make adjustments and put in the air again tommorow afternnon
DO EVERYTHING YOU CAN TO KEEP WEIGHT OUT OF THE TAIL IF YOU ARE GOING TO USE THE OS 1.60 OR AN ENGINE OF THE SAME WEIGHT OR LIGHTER. Otherwise you will have to put weight in the nose, it will not fly well if the c/g is past the recommended spot
No crash or anything bad, just uncomfortable the first flight.
BTY, the os 1.60 is PLENTY of power
zonk
