Reading this thread, it occurred to me that you could put a balsa spacer inside the plane for a standard switch mount method. Then get slightly longer screws and viola, the top of the switch will be flush with the side of the plane. It is then no problem to use your finger tip to turn the plane on and off. I like the in and out switch but in some of the smaller planes space can be an issue. On my current plane the side wall was too thick so I used an in and out. Problem is that I will have to remove it each time I want to remove my receiver for whatever reason. On the other hand, with my few brushes with the "tall grass", switch position would have been the least of my problems.
Jeff
