RCU Forums - View Single Post - u-can-do 60
Thread: u-can-do 60
Old 02-23-2004 | 02:37 PM
  #83
autoguns's Avatar
autoguns
Default RE: u-can-do 60
Lord Lucan I think the 90' manifold and the flex to the muffler will work fine....The fuel consumption of the os I had In the plane was good about 17min max 10min easy don't forget to use a seamless tank if you plan on upgrading to a YS110fz.....
Kroflite54....I haven't had a problem with the landing gear But I did beef it up ...It make's the job easy if you cut a small hatch in the top of the fuse under the canopy,do the mod's and then re-cover...I had a os 91fs turning a 14x6 topfite it worked good It would hover no prob...I then used a APC 14x4w and that worked better...I'm a power pig so I swapped the OS91 out and put a YS110fz in now the plane will hover @1/3rd throttle, instead of 3/4 to 7/8 throttle.......Some right trust is good and on mine a little up was needed....JW
