RE: Weak Ryobi
RCING1, thanks for the tip. Great site, with loads of info. Too bad there is nothing on the ryobi. The port timing figures in the "hot rod" section look a little too stout for a slow reving Ryobi. Think that I'll try to "sneak up" on the 160 deg exh. figure, a little at a time, & check the results about every 5 degrees. Thanks again. ....... Geo.K.
