I'm assuming this is the initial cost plus prop and other goodies.
Well, that's the VERY basic essentials. But in addition to the plane, engine and radio equipment, you'll need to spend another $150 to $200.
Here's why.
1) You really need to join a club to fly glow powered RC, almost every club requires that you have an AMA membership (for the liability insurance), and AMA is $58 per year (if your over 18). Here's a link.
http://www.modelair.org/
2) Club membership will be somewhere between $25 and $125 per year.
3) Other stuff you'll need: Fuel ($15 per gallon), 3 feet (minimum) fuel line ($5), Fuel Pump ($15), Glow Plug Igniter and charger ($20), if there's any way you can afford it - 12 volt starter for the engine with a 12 volt battery and charger ($65), an extra glow plug and a couple extra props ($10).
4) Then you'll need some CA Glue ($5), some 30 minute Epoxy ($5) and other stuff you may or may not have, like screwdrivers, pliers, small saw, sandpaper....
One thing this hobby is not, is cheap. [
To start with new equipment and buy everything you'll need including memberships, I usually tell folks to expect to spend $450 to $500.
Go to those clubs FIRST! They may have a club trainer that you can start with, or someone may have a used trainer package they'd be willing to sell cheap. (I've helped people get started with plane, engine, radio and a few extras for about $150 a couple times.)
I'm not trying to discourage you, but thought you should know the truth before you jump in.
Good luck, have fun, and welcome to RCU!!
Dennis-
