Brison 3.2 Which Prop?
I would recommend that you use a 22/8 or look at some of the carbon props that may be in slightly larger sizes. Keep your RPM's down under 7500 and things should run and sound good.
While you may be able to get a lot of thrust with the 22/8, if your engine speed is too high, you may have too much prop noise.
