RCU Forums - View Single Post - Source for cut thread push rods
Old 02-24-2004 | 11:50 AM
Gordon Mc
Default RE: Source for cut thread push rods
ORIGINAL: Matt Kirsch
Any particular reason you're looking for CUT threads as opposed to rolled?
Probably because I told him that in my experience the rolled threads are generally a little "looser" than cut ones. Additionally, a cut-thread pushrod is typically a little stiffer because the diameter of the pushrod is slightly larger (in a rolled thread, the material is pushed up to form the peaks of the thread; in a cut thread the rod must be as large a diameter as the highest peak of the thread).
Rolled threads work too - but IMO you are much more likely to need a fairly thick threadlock compound to fill in the gaps.
Gordon
