RE: Recommended control throws for Edge 540T
ezflyr
If your looking for the plane to be docile at the indicated low rates, you should move the cg forward to about 4 to 4 1/4 inches. When we flew the plane a 4 3/4 cg it was very sensitive on low and high rates. We moved the cg forward and it smoothed right out. The ailerons work just fine at either cg setting. I hope this helps, those used to large planes with sensitive surfaces will do well just where the plans call for, but it was too much for me
Hope this helps
Dale
