RCU Forums - View Single Post - BIG problems with Eclipse7's in AUSTRALIA
Old 02-25-2004 | 07:58 PM
  #31
SmoothPass
Default RE: BIG problems with Eclipse7's in AUSTRALIA
.....XJet, it sure sounds like you really know what your talking about"like paranoid said"!.
Thanks again for your input.
Something sure is really wrong with my TX.
Unfortunatly I can't swap the RF module as I cant borrow or afford another one.
For now I might have to just let the radio gather dust, or use it as a wheel chock.
Also last night when doing some more testing I noticed that when I turned my QPCM TX on it splattered"caused interferance" with another model I had on the bench at the same time."the othe model is on different frequency with its own TX and RX".
The second plane is all hitec gear "Flash 5" and works fine,"flown daily". I had it powered up and sitting on the bench,,,,,, And I noticed that when I turned my QPCM TX on it caused massive iterferance with the other plane on different freq.QPCM is on .633and other plane .643.
So I ran inside and grabbed another Flash 5 TX that is also on .633" when I turned this TX on it caused no iterferance. So it would seem that the QPCM TX along with its other problems is transmitting way off frequency?.
Also during a range check with Qpcm tx it improves from 5meters with arial down to about 10meters if I hold onto the arial with my hand. With arial pulled out about 15cm"the first thin bit only" It, the range then improves again. to about 20 meters. By the way my 2 Flash 5 TX's with arial all the way in work fine for about 60meters.
Thanks for your help EXJET.
