RCU Forums - View Single Post - UCANDO ELEVATOR QUESTION>>>>>>
Old 02-25-2004 | 09:30 PM
autoguns's Avatar
autoguns
Default RE: UCANDO ELEVATOR QUESTION>>>>>>
If you are using the same make of servo's Put the control arms on the servo's as pur the manual ..IE one on top and one on the bottom and it will work just fine...The elevater servo in the picture arm is pionting up to the top the right side the arm is pointing down... .JW
