RCU Forums - View Single Post - reading Prop Specs
Old 02-26-2004 | 01:09 AM
RichLockyer's Avatar
RichLockyer
Default RE: reading Prop Specs
ORIGINAL: ke5in
Since the 8x6 turns slower and creates less thrust (Geistware above) is that because it is “working against” the motor more because the pitch is greater than the 9x7 and, therefore, the 8x6 would seem to create the most load?
I think you misinterpereted his answer... I know I did.
You asked about the 8x6 compared to the 9x7, and he gave you the parameters of the 9x7.
The 8x6 will probably spin about 2000rpm higher. Top speed would be slightly more, but static thrust would be slightly lower... BOTH of these numbers are very close though, so I'd say that both props would end up being comparable AS LONG AS you aren't overloading the engine with the 9x7.
