If it falls off to the right, and you need to hold left, mabey you have too much right thrust?
Anyway, when the belly is towards you, push the rudder in the direction that the plane falls out. In other words, with the belly towards you and the plane falling out to the right, push the rudder to the right also. Just a little trick that helps. My $0.02
3D-kid330
