RE: World models Sky Raider...Any good?
I am putting together the low wing. it is my first attempt at a "build". I haven't had too many problems but i test fit the wing to the fuselage this morning and it doesn't seem to want to sit in the opening properly. I am confident i assembled the wings properly but the trailing edge that bolts down doesn't seem to want to sit all the way against the fuselage. is that a normal thing to run into. and should i fix it by notching the fuse a little more or notching the tip on the wing?
thanks for any help
Ray
