ORIGINAL: wrongwaywayne
mount the engine at 90 degrees and add a fiberglass cowl. I also converted it to a tail dragger. That nose wheel is responsible for most of the damage the plane takes
Wayne, Can you post a pic of the cowl and front end? Exactly where did you get the cowl? Also how much right/down thrust is needed with the tigers both vertical and horizontal orientation?
Thanks WWW! Sorry to hear bout the crash. Every picture I've seen of the Tiger as a trike looks like its doing a wheelie. I think it looks more civilian as a taildragger.
