RE: World models Sky Raider...Any good?
Ray-
This is a common problem, I deepened the notch in the fuse a bit (do it a very little at a time and check for fit), and everything went fine.
The plane is a great flyer, and pretty darn quick with a Thunder Tiger Pro.40. I raced another guy with a Pro .46 on his, and my .40 with a 9x7 APC had a slight speed advantage on a long straightaway, I am going to try a 9x8 APC today. We even banged wings at one point and both survived the incident; couldn't find any damage on either plane.
The pitch is very sensitive, so do NOT exceed the recommended throws on the elevator; mine is set 2mm less than the instructions state, and it is plenty...Dale
