RCU Forums - View Single Post - Draganflyer formilitary use???
Old 02-26-2004 | 02:16 PM
Super-Hornet
Default RE: Draganflyer formilitary use???
Hi Wolfpack duce
If you really serious about it... I still think Draganflyer (4 Rotor Flying Saucer) NOT UP TO THE Task.
Why?
The blades are weak.
Lifting maybe a problem. I think u are going to use Military Standard TX at least so your Receiver might be big also. Video Camera are small so should not be any problem but U need a good Transmitter for your video. I don't think u going to use those milliWatt of transmitter (Commercial for parent to spy kids) because your signal might get block by building or trees. So u need a higher wattage transmission power. Let say u go for 1Watt... your TX for video is going to be bigger and so do the power consumption. Therefore u need bigger battery also. With all that... Draganfly may not able to carry all those weight.
Possible choice:
1. Corona
2. Hornet
3. Nitro Chopper.
Super-Hornet
