Wing Balance
SIMPLE QUESTION: Are you sure the wing is on the plane perfectly, same distance to each wing tip from the center line in the fuselage? I've had the wing on less than straight, or ended up slightly longer on one wide than the other from the center of a one-piece wing. A little too much length on one side has a tremendous weight when 20 inches away from the center line.[img]i/expressions/face-icon-small-smile.gif[/img]
So much to check , and so little time between flights.[img]i/expressions/face-icon-small-happy.gif[/img]
