RE: question on unstable edge 540
it is snapping because your wing is stalled. once the wing is stalled, it is useless, and any little diference will cause it to snap. the reason is it is too heavy. when the plane is too heavy, the inertia from the moving plane is so much that the wing's surface isn't large enough to handle it and it will stop flying. the only real solution is to loose weight.
