RCU Forums - View Single Post - Clean Blades
Thread: Clean Blades
Old 02-26-2004 | 10:50 PM
Mini Boy
Default RE: Clean Blades
Hi Larry, Darth, Colstonman, Gmaster, batjac. et. al:
The warning label in question states that "rotating blades can cause serious injury" , and "always wear appropriate eye protection". Why, then, does every one want to remove them. It may even be illegal to remove those labels in some states (like California)??
Perhaps the manufacturer wants them to be left in place, hence the difficulty in removal ?!? In which case the warning should be molded into blade in the injection molding process.
THEN ...... it would it be fairly simple to use an additional easy peel-off label, and eliminate all this possible damage to the blades that may cause injury / darth ---- sorry, I mean death, by using chemicals or solvents to remove the labels?!?! Oh, and reduce the frustration of some / most of the builders ?!?!?
Larry ...... we need you!
Just my ten cents worth again.
Happy and SAFE flying,
Russ
