John,
I took the written test on 2-6 and scored a 92. Hopefully that is good enough to get me a little break, we will see. I can handle 45 minutes, not 4 hours like some others I have talked to!
Sung,
I BARELY found the time, actually had to borrow a little from other areas, like model jets.[
] But I wanted to finish as fast as I could, owning a plane is very expensive even when it is not in the air! So if it going to cost me money, it might as well be flying me around! I will be at the Basin as soon as I can "crear the plate" a little. Are you going to Tucson?
LOOK OUT BUCK!!! JOININ THE MARINES TO FLY WITH YOU NEXT!!!!
Hope to see you in Tucson too buddy! Better bring the monster 18!
