RCU Forums - View Single Post - Dynaflite Decathalon?
Old 02-27-2004 | 07:34 AM
beepee
Default RE: Dynaflite Decathalon?
Hulapig1,
The OS 1.60 should be fine, but maybe a bit light on power. If you are an experienced builder, spend some time taking weight out of the aircraft, as much as possible without compromising the structure. Like those above, I have powered mine with a Quadra 42 swinging an 18x10 prop and it provides more than enough power.
If you use the 1.60 and build light, the stock gear should be OK. I had the same experience as Hurri and made a similar modification. No more gear problems. I also think the plastic cowl and wheel pants are junk. I assembled and finished mine (because they were free, after all), but now think that I have wasted too much time and will soon have to replace with fiberglass.
The Decathlon will reward your efforts in the air. It is a very capable flier.
Have fun!
Bedford
