Venus or Aresti?
My Aresti balanced perfectly, but, I have several modifications. I am using pull-pull on the rudder with an extra servo mounted in the turtle deck. Also, I'm using flying wires on the tail. No nose over problems if you fly off pavement. When you look into this style of plane, realize that there is a difference between the "Stick" type constant chord and the pattern type double taper wing. The Aresti is not a constant chord fun fly slow flight design by nature. Acroman330, I know you realize this since you have a Hydeout, but someone else watching this forum may not.
TX
