RCU Forums - View Single Post - Installing windows in models tips needed
Old 02-27-2004 | 04:42 PM
CafeenMan
Default RE: Installing windows in models tips needed
If you make a router table for your dremel, you can use one of the thin steel cutters to slot the window frame around the inside. Then cut the window so it pops into the slot. The slot also gives you an easy way to guid the tip of the glue bottle and will help keep the glue from running out and making a mess.
