RCU Forums - View Single Post - To much Gap?
Thread: To much Gap?
Old 02-28-2004 | 01:58 AM
3D-kid330
Default RE: To much Gap?
ORIGINAL: MinnFlyer
If it's a trainer, just seal the gap with Covering or tape. It should be fine, as the speeds of a trainer shouldn't cause flutter.
BUT on your first flight, do a few close passes and see if you can hear a low-pitch "Buzz". If you do, land it right away and re-hinge the plane.
If not, have a ball.
I totally agree with MinnFlyer. MAKE SURE you SEAL THE HINGE GAPS or you will probably get flutter.
3D-kid330
