RCU Forums - View Single Post - concept 30 tail problem
Old 04-07-2003 | 10:05 PM
blvdbuzzard
Default concept 30 tail problem
I think they are the same. The tail was pretty much the same on all of the concepts as I have been told.
The other part of your message about an easy way to set up the pitch with a 4 channel, that does not really happen. The easyest way is to get a heli radio or a radio that will do both heli and fixed wing aircraft. The pitch and throttle can be setup with a "Y" cable and then you will need to adjust the linkage from servo to carb and servo to mixing base. It can take days to get it right with a 4 channel radio. Or you can set it up with a newer radio in about 15 minutes.
Dru.
