ORIGINAL: Slyder
What do you mean it save you battery at the same time?
Thats the only thing i hate about using my tx is always charging my batts.
Eric
Hi guys, I guess Eric has a good question, and a very important one. It is not just about saving your Tx battery life, but also saving the Tx RF module (transmission circuitry). I have come across many customers who damaged their Tx due to using a poorly designed adapter. What my adapter does is basically deactivate the RF circuitry when it is plugged into the trainer port, without the need for removing the Tx module and xtal (adaptors that need continuous removal of the module or xtal only causes damage to the contact pins in the long run, not to mention the inconvenience). Only the coding circuitry remains active to feed the necessary signals from the Tx to the simulator. Since the Tx is not transmitting, the power consumption is extremely low !
The adaptor is designed to work with all major simulators (Aerofly Pro, Reflex, RFG2) and is designed tough for a longer life. The adaptors will be available through a distributor very soon. Let me know if you have any other questions
