Dick
Thanks for you insight on this matter.
Would you use the KS-95S-4 or the KS-89S-4 ?
One being sized for 100cc the other for 85cc.
Both are front inlet / rear outlet smokers.
Bended outlet 90°
External-Aluminium-muffler
with integrated smoker
Part # 89S-4 95S-4
L. 300cm 280cm
Inlet 30cm 30cm
Outlet 18cm 20cm
Diam. 65cm 75cm
Weight 280g 320g
I was thinking that the 95S-4 would be the better choice,
being shorter (with a larger Diam.) to move the weight forward more.
Would the larger volume be less tricky to tune?
Asking to learn
