RCU Forums - View Single Post - Pipe length between engine and muffer
Old 02-28-2004 | 07:32 PM
rmh's Avatar
rmh
Default RE: Pipe length between engine and muffer
I hae not run the slightly larger one -but don't see a problem-unless it won't clear the gear - we used a 60 mm dia can.which is a copy -I think - no longer available I don't see either beig trick to tune - allow for 11-12" for header .
You will have to angle the can slightly - to not hit the wing tube -I think.
