RCU Forums - View Single Post - BIG problems with Eclipse7's in AUSTRALIA
Old 02-28-2004 | 09:19 PM
  #34
SmoothPass
Default RE: BIG problems with Eclipse7's in AUSTRALIA
XJET, you might know? I borrowed a mates Hitec programmer for a few days and used it to measure the pulse of the TX for each channel.
I noticed for example that when I checked say the rudder or elevator the readout would fluctuate when I move the throttle stick?. When moving the throttle stick it affects pulse of other channels, only by a 1 or 2 digits, but it does never the less. I then checked some of my flash 5's, they do it too!. Then I checked one of my JR radios, and it was perfectly stable, as in that pulse was not affected by any other channel, only the stick in command for that channel.
So my question XJET,,,, is it normal for the "elevator or rudder pulse" to fluctuate"be affected,,move jitter" when moving throttle stick on radios?
Thanks for your help so far.
