RCU Forums - View Single Post - Battery RX compatibility
Old 02-28-2004 | 11:34 PM
DBCherry
Default RE: Battery RX compatibility
As long as you connect positive to positive, negative to negative it will work. I believe the connectors will fit, but if using a Futaba connector you may have to trim the little tab off to plug into other makes.
Dennis-
