re: compression and nitro
A couple of questions for the experts.
1. In a situation where you suspect that preignition is going on, the answer is usually to shim the head or reduce nitro. How about running a colder plug?
2. It seems many european engines are designed to run strong on FAI fuel. Even though nitro is not as expensive in the US, why not do the same thing here? FAI fuel IS cheaper after all.
