RE: Which ngk plug for brison 3.2
On NGK, the higher the number, the colder the plug. Run the hottest plug you can without detonating. On these low comp. engines. the bpmr6a would be best. On champion plugs, their number system is opposite. the higher the number the hotter the plug. And yes, R stands for resistor plug. The other numbers represent the plug thread length, extended nose, electrode alloy etc.
