RCU Forums - View Single Post - GSP Corsair - Need Advice Please!
Old 06-09-2002 | 12:35 AM
Loopman
My Feedback: (195)
Default GSP Corsair - Need Advice Please!
I just got my GSP Corsair and I must admit the workmanship is 1st rate! I do have some questions for you guys that have built and flown this bird, so please help!
What is the best way to connect the individual flap sections so they will be sturdy and move together in unison?
What is the best glue to use for joining the wing panels? (I have never had much luck with regular epoxy on fibreglass.)
The tailwheel assembly looks light, any suggestions?
I am installing Robart 615 retracts with Robart 650 struts and 3 inch scale wheels. I looked at the setup that one of the fellows did on the other post and it looks fairly straight forward.
I will be using individual servos for the flaps instead of the supplied wire pushrods.
I am installing a ST2300 for power, should be plenty enough for this bird.
Should the balance point be established with the gear up or down?
Thanks in advance for all and any suggestions you may have!
Happy Flying!
LOOPMAN
