bigsport, Keep workin on it. sounds like your real close to having it down. Getting used to seeing the belly is your next hurtle. just keep getting lower as your confidence rises. youll be torkin on the deck in no time
When the fazer dies (and it will, if you aint crashin you aint learnin) replace it with a better suited plane. Taco, burrito, omp, sledge, Etc. and it will really get easy.
Best of luck to you
