RCU Forums - View Single Post - basic aerodynamics
Old 03-01-2004 | 03:09 PM
  #42
banktoturn
Default RE: RE: basic aerodynamics
Dick,
Lower wing loadings increase the usable CG range only in the sense that a slower flying plane can be successfully flown with a smaller static margin. That is much different than saying "1- If the plane is extremely light - the CG does not matter". I have no problem with people using exaggerated, or otherwise absurd, statements to make a point. I personally was not able to pick up on the fact that you were using absurdity in this way. To me, it simply looked as though you were making an incorrect statement. Presumably, a beginner, looking for some basic aerodynamics advice, would be more perceptive, and would not be at risk of trying to fly an unstable plane based on your post.
banktoturn
