RE: Choke closing due to vibration
Jim, if your using the standard plate that slides sideways across the carb like the motor used while it was a trimmer, you might have to bend it a bit so the stamped indent fits into the notches ment for full,half and no choke. It might be possable to have it installed backwards too, just turn it over in that case. piper
