RE: Pressure testing engine
Albert:
Shouldn't leak much unless it's an airbleed carb. Dunk it in some varsol or kerosene and you'll be able to see exactly where it's coming from. I use the same method only from the other end and using a large fuel line over the carb intake and turning the crank till the exhaust and transfer ports are closed.
