sullivan smoke pump works part time??
I have a sullivan smoke pump on my new plane, it puts out good smoke when it works.It seems to quit when you level out but then I cant get it to come back on.The pump is running but nothing happens.Could this be due to the valve that that they give you with the pump.What happens if you dont run the valve in-line?Anybody have the same problem?If so what is the fix?
Thanks, Todd
