RE: G2 Snapshots??
Jeff, v-max56, and MadDriver,
Thanks for the compliments. Most of the schemes are based on actual planes although some I have made up.
The parked planes are just short recordings (3 seconds or less) of stationary planes - all played back at the same time. Taxi the plane you want to a location, hit the "r" key to record for a second or so, name the recording and then play it back. Choose another plane and then repeat the same sequence. The overhead shot down the centerline of the "noon time lineup" was I think 22 recordings. One hint: it's a good idea to hit the stop button of each recording because the sound of all the engines idling can drive you nuts.
Lou
