RE: Wrinkles
The wrinkles will have very little effect. Don't worry about them too much. Sometimes... its better to just not mess with it.
If you REALLY want to get rid of the wrinkles.... You can take a household iron and get most of the wrinkles out.
If it has the self-stick covering (I think that plane does...) then the covering will not handle heat well... but it can be carefully shrunk a little. Start down in the delicates area... and be careful. (test on the TE of the aileron... where if you melt the cover it won't be a disaster. Hold for 5 sec, and if its going to melt... it will.)
If it has Monokote... you can set the iron right at the steam line with most irons. (start a little lower.. and if it won't shrink, turn it up a little.)
