ORIGINAL: NOVAflier
Paul, How did you get the surfaces to move so slow in your butterfly example? Is this a setting on your radio?
The way it works on my transmitter is that it's hooked to the throttle stick. At full throttle there is no butterfly. As the stick is pulled back there is more butterfly. The butterfly mode can be turned on or off by a switch.
