RE: help with control throws on a Nexstar
First, is your aileron trim lever in the center? Your servo problem may also be related to your Transmitter. What Tx are you using?
As far as the aileron horn goes, are you using the outermost hole on the SERVO arm? If not, do that before you move the clevis closer to the bottom on the aileron side.
