RE: Radio Programming
Exponential settings may be used to change the response curve of the servos to make flying more pleasant..you can make the servo movement less or more sensitive around neutral for aileron,elevator,throttle and rudder.......this according to Futaba set up manual..usually people just use dual rates as opposed to exponential values....the faster you go, the less throw you need for the same manuver......Rog
