RE: Radio Programming
Exponential allows you to make the sticks on your radio less sensitive around center. This can be helpful if you have your control surfaces on your plane set up for large throws. This way, your plane handles a little more like it has mild throws when the stick is near center but the control surface moves at a higher rate the farther you move the stick from center.
