RE: Engine changeout
It does mean you will have to add weight.
However, since the tail is much farther from the CG than the nose, you'll wind up adding a lot less weight. You could calculate how much weight, it's weight * distance from CG, but I'd just mount the engine and add as little weight as far back on the fuse as you can get it.
