Day Three - Bellcrank
They have come up with a pretty nice bellcrank assembly that is smooth and eliminates the differential throw that you get with a two servo setup, or "Y" type arrangements.
It installs very easily and the only thing I saw that needed help was that I ended up adding a spacer on each side between the fuse and the control horn to keep the slop out.
Don't forget to add the holding screw for each control horn.
