Flight Update
I've had the chance to fly the Super Sports Senior several times now and am still very happy with it's flight performance. Flights have been in varying weather conditions, high/low winds, and the plane tracks very well. In a higher wind, there is a slight tendency to weather vein, but that is really true of any of my planes except my Ultra Stick.
I did move the CG back and the plane knife edges very well. If i move it back more, I imagine it will climb in knife edge flight.
Flying with a gasser, one is always suspicious of what the vibration from the engine can do to the airframe. I have inspected the frame several times and things are holding up just fine, nice plane!
I put together a very easy design for adding a tow release for towing gliders. When I put this in, I will post a pic.
One last thought. I did use the detachable tail assembly and it has held up perfectly. I will probably install wires on the tail just because it helps keep the tow line from getting caught on the stabs. I could also use some weight back there anyway.
If you have an interest in flying a smooth aerobatic, but gentle plane, take a look at the World Models Super Sports Senior, you'll not be disappointed!
