RCU Forums - View Single Post - Shortening the Fuselage
Old 03-06-2004 | 09:14 AM
swooper's Avatar
swooper
Default RE: Shortening the Fuselage
I don't see why you can't rebuild at the original length with reasonable weight. Short doublers at the joint between front and new rear sections shouldn't add much.
OTOH, if you shorten 10 percent, add 10 percent to all surfaces to retain the intial stability.
